Old 26-05-2003, 19:11
RX-7 freakske's Avatar
RX-7 freakske RX-7 freakske is offline
Tokyo xtreme racer
Heeft er iemand code's van dit spel? Het is een spel op de playstation 2 zeer mooi en fijn spel trouwens.
Alvast bedankt
Greetz the little one
Old 04-06-2003, 22:45
Snelle Japie's Avatar
Ik heb eens gekeken op een site vol cheats en heb dit gevonden voor PS2:
Decorations:
(submitted by: beyen68)
Press & hold the following buttons while choosing your shift assist option. Keep pressed until the game has loaded:
R2 + X + Circle - Genki Gremlin
L2 + X + Circle - Blue mosquito
L1 + X + Circle - Dog
R1 + X + Circle - Pink creature
White Carismo car:
(submitted by: BigTommyGUN)
Defeat the last Zodiac (White Carismo) to unlock his car and get about $4 million dollars. To get $5 million dollars when you defeat White Carismo, let him win the first time he challenges you. Then go up, challenge him, and win. At the ending you will see a message appear that saying "Challenge Ending = 5 Million Dollars".
Skyline car:
Defeat the Speed King to get $3 million and unlock the Skyline car for purchase.
Display replay meters:
During a replay, press Select.
View one-on-one battle positions:
During a one-on-one battle, press Square to see the positions of all other cars.
View free run positions:
At the course selection screen in free run mode, press Square to see the other cars.
Control replay view:
Start a replay in the driver view position, then press L1 or R1 to pan the camera.
Fixed replay view:
Hold Triangle when the replay is about to start.
Full pause screen:
Pause the game and press Triangle + Square. Press Triangle + Square again to restore the pause screen.
Delete scores:
At time record screen, hold L1 + L2 + R1 + R2 and press Start.
Analyze option:
Pause the game immediately when you start a drive in quest mode. Scroll all the way down the pause menu to access an "Analyze" option under "Retire". This allows you to see the turning rate, accelerator, and brake pressure. This only works at the very start of the drive and you cannot turn it off once enabled. Note: This may be dependent on the car type or parts.
Siren:
Set the rear spoiler to type 5 for the R30 and R30M, then use the horn.
New nickname:
Select any team sticker for your car and the team will get a new nickname.
Car part preview:
Select the exhaust or aero at the parts selection screen. Press Triangle as the view zooms in to keep the camera away from the car. Press Triangle again to resume the zoom.
Alternate loading sequence:
(submitted by: The Chill)
Hold R1 while selecting a transmission type. Keep the R1 held through out the loading screen to see a man hanging from the roof of your car in first person view
Wanderers Requirements:
While not exactly a cheat, this will allow you to race some of the wanderers that you may have missed in order to unlock the final racer.
#316 Will appear when days are a multple of 7, you must have a shindowa plate
#319 you must have an import car and 180 days must have passed
#326 FF type car needed, days must be a multiple of 10
#328 6 cars needed in garage
#329 will appears between 9-11pm
#330 shonan plate needed, days must be a multiple of 7
#331 will appear between 2-4am
#334 must have under 30mi. on odo.
#338 first two numbers in days total must equal four (ex. 220days) and you must be using a two seater
#340 odo. must have 2000+ mi.
#341 must have 25 cars in garage
#342 odo. must have 120mi. or less and you need to use the stock exhast.
#370 your car must be equipped with the stock engine.
Car Ornament:
(submitted by: Smart Yabbo)
At the "Course Select" screen sfter you have chosen whether to enable shift assist or not press and hold R1 until the race is finsihed loading. If you then go into first person mode you will see a little hanging ornament in the top left corner
En nu racen !!!
Old 05-06-2003, 11:36
Bedankt voor de codes en hints, weet jij misschien ook nog hoe je meer banen krijgt want dat vind ik niet.
webmaster van: www.kellyjamers.com & www.vanherck-racingteam.be
