Old 16-01-2004, 23:13
Superdiesel's Avatar
Drive-through's en Stop & go's afgeschaft
Penalty shake-up is approved
Three strikes and you're in trouble
The FIA, the sport's governing body, has rubberstamped plans revealed by AUTOSPORT last month to overhaul grand prix racing's penalty system for unruly driving.
FIA president Max Mosley confirmed the news following a meeting of Formula 1's team chiefs in London on Friday. It means that drive-through penalties, such as that which ended Juan Pablo Montoya's 2003 title hopes in the US Grand Prix, will no longer be handed out.
"[Following a dubious on-track collision] there will be a hearing after the race and then a penalty will be imposed, depending on the gravity of the offence," Mosley told Reuters after the meeting. "If that happens three times in a season the stewards are going to look very seriously into giving a one-race suspension. It won't be automatic but they will look at it very seriously."
We don't want to discourage people from racing
Max Mosley
Mosley added that the penalty point system would not be exactly the same as that used following road traffic offences in many countries, but would be similar in method.
"This is more flexible than that, but there is the principle that someone who keeps on causing an accident in a dangerous way will be looking at a suspension," he said. "We don't want to discourage people from racing."
Bron : www.autosport.com
Amai, wat gaan we nog krijgen?
En wat dan de laatste 2 races? Ram elkaar maar van de baan, je krijgt toch enkel een verwittiging.
Old 17-01-2004, 00:04
2 laatste races rammen, is volgend seizoen raceje missen ?
Maar d'r staat duidelijk dat het dus niet zomaar beslist zal worden, maar dat d'r dus eerst goed onderhandeld zal worden vooreer er zo'n penalty wordt uitgedeeld.
dus feitelijk vind ik best een goed systeem. Dan gaat men achteraf niet zo hard zagen op 'wat had d'r kunnen gebeuren als hij die drive-through niet had gehad' etc....
Nadeel is natuurlijk, dat je het nu kan veroorloven om bij belangrijke wedstrijden eens wat minder sportief te zijn. Nuja, elk heeft z'n voor en nadelen.
Old 17-01-2004, 16:12
Baron's Avatar
Baron Baron is offline
Touring car racing !!!!!
En dat kan voor vuurwerk zorgen als in de laatste Grand Prix het kampioenschap nog moet beslist worden. "Ik tik mijn tegenstander nu van de baan, haal de titel binnen en volgend jaar mis ik wel een race"; dat zou wel eens de redenering kunnen worden.
In het recente verleden zijn er al zulke situaties geweest. Denk maar aan Senna-Prost, Schumacher-Hill en Schumacher-Villeneuve. Dus waarom zou dat in de toekomst ook niet kunnen?
Old 17-01-2004, 19:27
'k vind dit wel een beter systeem. Dan zullen wellicht de discussies van terecht of onterecht opgelegde straf verminderen.
