Old 22-08-2004, 20:33
Integra's Avatar
Integra Integra is offline
Service pack 2 voor prototype C mod (F1C)
Het 2e service pack van de prototype C mod is gereleased. Dit bevat een aantal Amerikaanse group C wagens. (Chevy Intrepid, Toyota Eagle MkIII)
meer info hieronder:
FEATURES:
*- Three years (1991-1993) worth of Toyota Eagle MkIII racecars with both year & track specific variations.
*- 1991-1993 Chevrolet Intrepid RM-1 teams of MTI Racing, Scandia Motorsports and Tom Milner Racing.
*- The 1992 TWR Jaguar XJR-14GTP team of Davy Jones and Arie Luyendijk.
*- Phoenix International Raceway infield track.
*- Rolex24H infield track.
*- Retextured Sebring International Raceway (original track by RSDG).
*- Retextured Laguna Seca Raceway (original track by SBDT).
*- Retextured Mid Ohio Sports Car Course (original track by Spider).
*- Retextured Watkins Glen NT2003 conversion.
*- Support files for three new seasons: IMSA92, SWC91, SWC92
*- New commentary and vehicle sounds.
*- High resolution mirrors.
REQUIREMENTS:
_______________
Full installation of Prototype C with Patch and Service Pack 1.
250Mb Hard disk space
INSTALLATION:
_______________
1.) Run Prototype_C_ServicePack2.exe
(Important note: The installer program may point to your F1 2001 directory by default. Be absolutely sure you've redirected it to the F1 Challenge 99-02 directory!)
2.) When prompted, Locate your F1 Challenge 99-02 directory and select F1 Challenge 99-02.exe Click OK
3.) When prompted, Select your PrototypeC.ini file from the same directory. Click OK.
4.) Click Install. Wait....
5.) Find the new cars and tracks in each of the PTC91, PTC92 and PTC93 seasons.
PHYSICS MODELLING DETAILS AND SOME SETUP TIPS:
Toyota Eagle MkIII (1991)
Weight: 840 kg (empty)
Power: 785 hp @ 8,500 rpm
Downforce: 3067 kg @ 321 kph (max)
Top Speed: 319 kph (198 mph)
Introduced halfway into the 1991 IMSA GTP season, this car represents Dan Gurney's first real championship challenger. The small 4 cyl 2.1L turbo engine allows a low mandatory weight, and allows for large underbody tunnels to be fitted. Even though this car is capable of generating significant levels of downforce, it is in early stage of development and reliability is still a question mark. It does have all the ingredients to be a future winner...
+ good handling
+ powerful engine
+ high downforce
- early in development
- reliability unknown
- peaky engine performance
Chevrolet Intrepid RM-1 (IMSA 1991)
Power: 800 hp @ 7,500rpm
Downforce: 4390 kg @ 321 kph (max)
Top Speed: 291 kph (181 mph)
This distinct Bill Riley-designed car is a no-compromise high-downforce car, with a fairly standard 6.0L Chevrolet V8. This engine allows for a relatively low mandatory weight of 840kg, making this car a dangerous customer at the high-downforce tracks. Questions still remain about its performance on high speed tracks, as the top speed is severely limited due to the high drag, high downforce body.
+ Good handling
+ Lightweight for a GTP car
+ Very high downforce capabilities
+ high power, high torque V8 engine
- very high drag
Jaguar XJR-14 (IMSA 1992)
Weight: 800 kg (empty)
Power: 697 hp @ 11,500rpm
Downforce: 4073 kg @ 321 kph (max)
Top Speed: 321 kph (200mph)
Having left the SWC championship after the departure of long-time sponsor Silk Cut, TWR fields a modified XJR14 for the 1992 IMSA GTP championship. Having soundsly thrashed the opposition in the first races, IMSA issued a 50kg weight penalty, which left the XJR-14 trailing the mighty Toyota Eagle MkIIIs for the rest of the 1992 season. Capable of a higher maximum downforce level than its SWC counterpart, this maximum levels does come at a higher drag as well.
+ Superb handling
- high drag at downforce setup
- weight penalty
Toyota Eagle MkIII (1992)
Weight: 830 kg (empty)
Power: 825 hp @ 8,500 rpm
Downforce: 4121 kg @ 321 kph (max)
Top Speed: 328 kph (204 mph)
When it was introduced halfway through the 1991 IMSA season, the Eagle MkIII took the field by storm. Now in 1992, the car is one of the main contenders for the title, equipped with a small 2.1L 4-cyl engine, allowing for a lower mandatory weight. Reliability over the long range is still a question mark, but the very high downforce levels this car is capable of generating make it a winner at any venue.
+ good handling
+ low weight
+ powerful engine
+ very high downforce
- reliability over long distance
Chevrolet Intrepid RM-1 (IMSA 1992)
Weight: 862 kg (empty)
Downforce: 4401 kg @ 321 kph (max)
Top Speed: 292 kph (181 mph)
The no-compromise high downforce car is back in 1992 with a 6.5L Chevy V8, raising the mandatory minimum weight to 862 kg. This larger engine provides more torque, thus making the car even more potent at the low speed tracks. High speed tracks will remain problematic, due to the no-compromise high downforce nature of the car, severealy restricting top speeds.
+ Good handling
- very high drag
Chevrolet GTP (IMSA 1993)
Back for it's third year, the 1993 spec car sports the same 6.5L Chevy V8 as the 1992 spec car. The big difference is the fact that the car is now a privateer affair, after the withdrawal of factory support to the MTI team. Like the other 1993 spec IMSA GTPs, steel brakes are mandatory. The aerodynamics have been felt unchanged, still being an all-out high downforce car. Should be able to take on the privateer Momo Nissan and Joest 962s, but the Toyota Eagles remain far out of reach.
+ Good handling
- very high drag
- steel brakes
Toyota Eagle MkIII (1993)
Weight: 910 kg (empty)
Power: 753 hp @ 8,000 rpm
Downforce: 4141 kg @ 321 kph (max)
Top Speed: 322 kph (200 mph)
The class of the 1992 IMSA GTP field is back for 1993, however slightly handicapped by IMSA. Like all other 1993 GTPs, the Eagle had to trade in its carbon brakes for steel ones. In addition to that, IMSA raised the minimum weight for this car to kg, together with smaller engine restrictors. The power output has dropped by 67 hp to 753 hp. Aerodynamics have been refined
+ good handling
+ powerful engine
- steel brakes
CREDITS:
_______________
Prototype-C_ServicePack2 by the Virtua_LM Team
a non-commercial race sim project
http//www.virtua-lm.com/
Special thanks to www.racesimcentral.com, our hosts and everyone that supports
and encourages us. Big shout outs to the ISI, RSDG, SBDT, RSR, EMAC, CLMF,
DiDT & SSM crews, GT40 Steven, Gjon, Mika, Tim Wheatley, CJ1045, Mikkel,
Albyno883, Amax, M@d69, Big Ben, Schlusel, NewNoBee, -}CosmiC{-Jtf2
,BullittStang, Dom D, sergec, Zevious Zoquis and all our friends.
Copyright & Permissions
All files in this Mod are copyright © 2001-2004 Virtua_LM Team
This mod is freely available to anyone, is strictly not for profit, and may
not be used for commercial purposes. Virtua_LM has no relationship with the
FIA, IMSA, ACO or any of the teams or sponsors, and copyrights of those
products reside with the individual copyright holders. The material provided
in this mod is not connected to Electronic Arts or Image Space Inc. No
support can be obtained from these companies for F1C if you have applied
this patch.
The files in this mod may not be modified by anyone or converted to another
video game unless permission is granted by Virtua_LM. This mod may not be
profited from commercially by a third party unless permission is granted
by Virtua_LM. If you downloaded this file from anywhere other than this
website then it is being mirrored and as such may be out of date. We accept
no responsibilities for losses or damage resulting from the use of this mod.
Download links (others will show up here as they come online):
Full Installer-
Boomtown - http://download.boomtown.net/en_uk/...iew.php?id=5956
Phil B - http://phillip.u24.nexxpowered.ca/P...ervicePack2.exe
Split download (8 parts X ~20Mb each)-
http://phillip.u26.nexxpowered.ca/P...ervicePack2.zip
http://phillip.u26.nexxpowered.ca/P...icePack2.zip.01
http://phillip.u26.nexxpowered.ca/P...icePack2.zip.02
http://phillip.u26.nexxpowered.ca/P...icePack2.zip.03
http://phillip.u26.nexxpowered.ca/P...icePack2.zip.04
http://phillip.u26.nexxpowered.ca/P...icePack2.zip.05
http://phillip.u26.nexxpowered.ca/P...icePack2.zip.06
http://phillip.u26.nexxpowered.ca/P...icePack2.zip.07
Old 22-08-2004, 20:55
sledge's Avatar
sledge sledge is offline
Toevallig, ik had net nog eens de oorspronkelijk mod gespeeld
Maar ik heb wel een probleem. Mijn F1c map is al meer dan 20gig groot, en mijn schrijfruimte word wat te klein :/
*edit*
Downloaden van Boomtown gaat moeilijk nu, er komt telkens een foutmelding tevoorschijn.
Old 23-08-2004, 16:07
yvdp's Avatar
yvdp yvdp is offline
F1C is een zwaar spel
greetz
Old 24-08-2004, 18:16
marcel's Avatar
marcel marcel is offline
ik heb juist Daytona geprobeerd met Sports Car Challenge (toch handig dat die circuits zo gemakkelijk overplaatsen tussen de mods he). t is een leuk circuit, maar uw remmen koelen zo gemakkelijk af op het oval gedeelte. ze staan gewoon koud als ge aan de eerste bocht of aan de chicane komt... da's wel effe wennen dat ge een stuk vroeger moet remmen dat normaal...
